NEW HELMET - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Riding Gear (https://cb1100forum.net/forum/forumdisplay.php?fid=18) +--- Thread: NEW HELMET (/showthread.php?tid=14052) |
RE: NEW HELMET - GoldOxide_imp - 11-08-2020 (11-08-2020, 07:21 AM)peterbaron_imp Wrote: Yep, maks a good match with your AT. I like it Thanks [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB. Been piling on the mileage since. There is no doubt for my pumpkin that this helmet is a win. Had no intention of looking at Klim, but I did review them a few months ago. The price turned me off, but like with many things, you get what you pay for. If I had the CB1100 I would likely remove the sun peak (takes about 30 seconds), and probably try to acquire a black version of the helmet. The helmet is even more quiet without the peak. I can't believe how light the Krios Pro is - and it challenges me whether I will ever go back to traditional [heavy] modular helmets again. RE: NEW HELMET - GoldOxide_imp - 11-10-2020 (11-07-2020, 02:06 PM)GoldOxide_imp Wrote: Got me this little tiddy the other day: Update: Already over a thousand clicks on this helmet and initial opinion has not changed. Anyone considering an ADV helmet and considering an Arai XD-4 (or similar) should also look at this helmet. Teasing out a few more opinions: (more) Pros: [ul] [li]Head turning is easier without the extra (inertial) moment caused by heavier helmets. This appears to help in lessening upper body/neck fatigue on long travel legs.[/li] [li]Surprisingly, early morning shield fog-up (forced with exhale from mouth) dissipates very quickly with face shield down. I guess the claimed air-flow management really does work. [/li][/ul] (more) Cons:[ul] [li]In my case, the chin strap is looser than I am used to in other helmets. The helmet won't come off, however, I typically expect it to be taut, especially with cold weather garb on under the helmet. This helmet strap will be quite comfortable with extra winter garb on. I suspect for riders with chicken necks, the strap could be a problem. If the rider has a double chin, they may really like this strap.[/li] [li]I am really getting down into the dregs now, but when lowering the face shield using the left side thumb tab, I often find myself grabbing the sun visor peak corner. Doing this does not allow me to close the face shield until I realize I am grabbing two things. This appears to only happen when I am wearing thick gloves for those cooler early morning rides. [/li][/ul] RE: NEW HELMET - peterbaron - 11-11-2020 I would appreciate a close range pic ( as the one above) but with everything "closed/down" TY. RE: NEW HELMET - GoldOxide_imp - 11-11-2020 (11-11-2020, 12:49 AM)peterbaron_imp Wrote: I would appreciate a close range pic ( as the one above) but with everything "closed/down" [url=https://www.klim.com/Krios-Pro-Helmet-ECE-3900-000?quantity=1&color=739] RE: NEW HELMET - Lord Popgun - 11-11-2020 I have a chicken neck
RE: NEW HELMET - GoldOxide_imp - 11-11-2020 (11-11-2020, 04:02 AM)Lord Popgun_imp Wrote: I have a chicken neck For you no helmet. Hmmmmmm.
RE: NEW HELMET - Houtman_imp - 11-11-2020 With a chicken neck you do not need a helmet as chickens can live even with their head cut off. RE: NEW HELMET - peterbaron - 11-12-2020
RE: NEW HELMET - Cormanus - 11-12-2020 (11-11-2020, 10:26 PM)Houtman_imp Wrote: With a chicken neck you do not need a helmet as chickens can live even with their head cut off. Not for long. RE: NEW HELMET - Lord Popgun - 11-12-2020 You’re killing me Smalls
