Oil Leak! Please help - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Oil Leak! Please help (/showthread.php?tid=5827) |
Oil Leak! Please help - Sfomoto_imp - 04-12-2015 Hello, I noticed while riding my CB1100 that there is a very small oil leak on the right side of the engine. There is no oil on the garage floor or other parts of the bike. It only occurs when I am riding, and I always find a little oil on the same spot. No smoke or smells on the bike when I ride. I am attaching some pics. ![]() ![]() All help is appreciate it. Thank you, Sfomoto ![]() Sent from my iPhone using Tapatalk RE: Oil Leak! Please help - CIP57_imp - 04-12-2015 I had the same thing happening on the opposite side. It's on the first second and sometimes works its way down to the third Finn. I took off the tank and loosen all the head bolts and re-torque them down. I found two just a bit more than hand tight. Make sure to use a torque wrench. RE: Oil Leak! Please help - lash_imp - 04-12-2015 I am without a manual yet, so what would the torque be? Also, while I'm asking about torque, what would the numbers be for the exhaust flanges bolts and the exhaust hangers? I am changing my exhaust out as soon as the new ones get here from Japan. Thanks for any help. RE: Oil Leak! Please help - CIP57_imp - 04-12-2015 I'm on vacation and not near my book, but I believe it's 16 or 17 foot pounds RE: Oil Leak! Please help - kevbroce_imp - 04-12-2015 I had the same leak. My mechanic put little washer under the cam cover bolt, top of your first pic. Tightened it back and problem solved. RE: Oil Leak! Please help - redbirds_imp - 04-12-2015 Do you mean head bolts or cam cover bolts? The 8 cam cover bolts, 10 NM or 7 lb ft. (04-12-2015, 08:36 AM)lash_imp Wrote: I am without a manual yet, so what would the torque be? Also, while I'm asking about torque, what would the numbers be for the exhaust flanges bolts and the exhaust hangers? I am changing my exhaust out as soon as the new ones get here from Japan. Thanks for any help. Manual lists "exhaust pipe joint nut" qty 8. I am assuming these are the flange nuts. 16 lb ft. All other values listed for hanger and joint clamps is 15 lb ft. Oil Leak! Please help - Sfomoto_imp - 04-13-2015 Thank you all for the help. I ll write an update as soon as I get it fixed. Sent from my iPhone using Tapatalk RE: Oil Leak! Please help - lash_imp - 04-13-2015 Thanks from me also... RE: Oil Leak! Please help - mininsx_imp - 04-14-2015 Just curious, the guys with the leaks, what kind of oil are you using? I've read for years where synthetic oil will sometimes seep out and dino oil won't. Oil Leak! Please help - Sfomoto_imp - 04-14-2015 I am using the recommended oil by Honda. Sent from my iPhone using Tapatalk |
