Full Version: YTX14-BS battery
I’m hopefully going to pick up a ‘13 in a few days. The owner let me know that the battery is original and may not last too much longer.
I have a new YTX14-BS in my garage. It’s the same length and width as the spec battery for the CB, but it’s quite a bit taller looking at the dimensions on the Yuasa website.
I didn’t think to study the battery and it’s installation in the bike. I’m wondering if a taller battery would fit ok based on its location and hold down on the CB.
Thanks
Not alot of room where the battery goes in the CB. I would be suprised if it fits.
The cables probably will not be long enough , go with a new Yuasa OEM battery , not cheap but very good.
What Houtman said. Plus, even if you manage to kludge up the cables, the tool box won’t fit back.
Thanks. I saw the tool tray under the seat and figured the battery was under it. Have to see once i get it home.
Or, think about being an early adopter and going with a new lightweight LiOn battery. One member, Flynrider, has reported success.
Thats where it is. Remove a screw and plastic pin and the tray lifts out. Battery is under it. There should be a strap around the battery to lift it out. It’s a real tight fit.
(04-04-2019, 10:55 AM)Cormanus_imp Wrote: [ -> ]Or, think about being an early adopter and going with a new lightweight LiOn battery. One member, Flynrider, has reported success.
Interesting.
I reckon Flynrider retro-fitted a LiON charger module with the battery? Or is the battery "smart" and comes with that electronics integrated into the battery?
(04-04-2019, 12:06 PM)GoldOxide_imp Wrote: [ -> ]
Interesting.
Not exactly sure what that is, GO. Are you talking about something that's installed on the bike with the battery? As far as I know, nothing like that is required. The CB1100's charging system specs meet the battery's requirements.
If you're talking about an external trickle or float charger, I don't use 'em. I ride the CB several times a week, year round, so I've never had a need for one.
Edit: I know that the battery has some smarts integrated. Comes with a button on top that shows state of charge, and it also has a cutoff circuit to prevent a deep discharge, which I inadvertently testing by leaving the ignition on overnight. Not sure what other "smarts" are integrated.
(04-04-2019, 03:48 PM)Flynrider_imp Wrote: [ -> ]
Interesting.
Hey Flynrider: Sounds like you answered my question in regards to battery internal circuitry. Good to know, and thanks.
